Hi all,
I have 1.6 verso mpv, the buttons on the remote/key fob has torn and come off/lifted off slightly, the buttons still work (see pics). Is it possible to get the buttons repaired/replaced or would I need to get a replacement key fob?
If I need to get another key fob, would I need to get it via a Toyota dealer and what is the approx price? Not sure if it makes a difference it one of the cars where you don't need to put the key into to start the car but insert the fob which has also has small key inside it
Thanks in advance
You can get another casing off somewhere like eBay (see here) - check it's the correct model.
Prize yours apart and transfer the key and electronics (will need to unscrew from casing) into the new one. Make sure you also transfer over the aerial rod if there is one.
