Rear Wiper Arm - 2009 Yaris
LordFridge
When I was changing the rear wiper blade today on my daughters 2009 Yaris, the clip in the arm itself snapped so I now need to replace that as well.
I remember on my son's 2001 Yaris, there is a difference between the arms for the French and Japanese built vehicles.
Does anyone know if it is the same for the later 2009 ones?
Hi, I can answer your questions directly but you can use this side to locate your car and find the parts you need and numbers. https://japancars.ru/index.php?route=catalog/toyota
One tip though, spray wd-40 now and every day a bit until times comes to remove the wiper arm as these gets stuck and almost impossible to remove. A small bearings remover can also be if a great help.
Good luck
