Cant remember if I've asked this before...
On the iQ you can change the clock on the small LCD when the clocks change so the time is correct. I do this by changing the time by an hour rather than any +1 setting which I'm not aware it has.
On the built in SatNav (TNS510, which I realise is fairly rare in iQs, but does appear in some other Toyotas of that era), I cannot seem to change it so that it shows times in BST instead of GMT. Although it doesn't show a current time, the ETA time for a journey is in GMT, and thus a hour wrong. Not the end of the world, but a bit annoying, and I've sat and gone through every button and setting I can find on the things and can't see how to get it to show the time in summer time +1.
Anyone got a SatNav and worked this out?
BST is also GMT time zone Greenwich / select to change
You may have + 1 hour Daylight saving Time /off-on
and auto ajust by GPS /off-on   If off manual time settings
This just may help you.
Perfect, thats done it thanks. Page 106 has the menu I had to drill in to... mine also I had to page down the options to get the timezone which I must have missed when looking.
  • Like 3
