2018 Yaris hybrid won’t allow connections to apps !
Clive Hickman
I have a Yaris  hybrid 2018 and I have opened a My Toyota account uk when I key that in and try and connect to apps it tells me to go to my Toyota.eu to register, that service is now discontinued! So I am stuck with no apps! Any suggestions had no joy from Toyota so far!
Connected services is a paid for service, My T app does nothing with the Mk3 login to My Toyota click on multimedia it will then have a pop up telling you to register the multimedia system, once you do that it will let you see the App's for the Touch2 you will need to do the TLS (low update)
be aware, you only get connected services with the touch2 and Go (Sat Nav)
on my 2017 I have changed the media unit with a junsun v1 pro, 1 year and 0 problems (for now....... 😄 )
everything works: camera, consumption, tyre pressure, ev information, wireless Apple car play....
Was this easy to fit?
Yes it was, but you need a minimal amount of DIY
The LCD is too much reflective, with a matte protection is perfect...the system read the OEM TPMS, the OEM camera and other apps like hybrid assistant, carista etc
the biggest problem is the camera with slower fps and the very bad quality mic, fixed with a cheap external mic
