Independent seats in middle row
Unaz
Hi All,
Currently owner of Toyota verso 7 seater looking at something newer and petrol/hybrid. We have 3 independent seats in the middle row which is the reason why we bought this in first place. I've noticed some Prius plus have 3 independent seats but others don't. Any idea which model came with 3 independent seats and which didn't.
Also is it possible to retrofit them if they didn't come from factory?
Thanks you.
Is it some of the ones you've looked at are UK ones while others are import ones? The Prius Plus didn't sell super well over here because they were excessively expensive compared to e.g. the normal Verso, but later on loads of them started getting imported from Japan and because they're virtually identical at first glance it can be tricky to tell them apart.
Auto trader normally lists them as imported. Don't think I've seen an imported 1 with 3 independent seats in middle row yet. All seem to be UK models so there must be specific trim or maybe it was an optional Extra.
The imported Prius plus has a standard bench seat on the rear and the official uk model has three independent seats.
The three independent seats gives some practicality but lack some comfort on long journeys. Those can be interchangeable but I am not 100% sure.
The second roll in the boot are the very good one , although limited space only ok for a small children they are so easy to fold or set up.
The Prius plus is great car for families or business. Perhaps the reason that was discontinued in uk earlier was not sales numbers but Corolla TS that came into the market. If you need car like that highly recommended to buy used plus no matter the seat numbers. 👌
