Prius A/C leak
timf1981
08 prius a/c only stays charged for abou a week.
I did put some dye in the system but can't find he leak.
The evaporator replacement is an 8 hour job.
Is there anywhere I can get a look at the evaporator to see if there is some oily dirt on it.
Are there any common leak areas i should triple check?
The evaporator is the least likely place for it to leak.
The most likely place is the condensor followed by a pipe under the bonnet.
