UK 2006 Estima ACR55W tie rod Nearside
HI All,
Does anyone know where I can get a tie rod for a Toyota Estima. I have tried the usual places but they are either too short or too long. Only option is compete rack replacement.
thanks
Built 03/2006 so an early 2ng gen Estima (aka Esteem in some markets)
you may find you need to buy the matching tie rod end to get the same overall length, had this a few times with aftermarket stuff
the inner tie rods are not listed as OEM, just a complete rack 45500-28080 for your year and model tie rods are only listed for 12/2008 onwards
Tie rod ends
RH 45046-29515
LH 45047-29195
Edit, found an aftermarket reference Sankei-555 (made in Japan) SR-T480, matching ends SE-T481R and SE-T481L also sold under Yec
No doubt this is the part you have pictured
https://www.yec-auto.com/product_view-product.php?pId=7710
Any matching part numbers Flash22, from a Camry or similar as the Estima seems to be made from Camry parts?
only model i can see it crossed to are.
ESTIMA
PREVIA
ALPHARD
ALPHARD(AYH30)
ESTIMA HYBRID
VELLFIRE/ALPHARD/HV
LEXUS LM350/LM300H
As i said above pre 08 the oem list a complete rack only
