Resetting trip meter on Yaris Y20
Keith E
Just picked up a used Yaris Y20 2019/20 hybrid.  Trying to reset the trip A and trip B meters but manual does not seem to help.  It has the colour display with type A control and no obvious button (as on old version) to press for reset.  Previous owner obviously did not reset as both trips are same as odomenter.  Can anyone help?
Usually, whatever button you press to cycle between Trip A, B, Odo, etc., also resets - You just hold when it's displaying the counter you want to reset (e.g. press it until Trip A shows, then press and hold it until it's reset to 0)
It tells you on the screen 😃 I think it's the Trip button to cycle the trip, press and hold to reset, can't be bothered to walk to the car ATM
Edit. From that Spanish waiter
  • Haha 1
its easer to press the button below the speedo then when trip A is displayed just press and hold until it zeros. Do  the same for trip B.
It goes through a cycle om MPH. Trip A , Trip B, and Milage to next service.
  • Confused 1
No buttons on the gauges at all after 2017, unless is ultra low poverty spec, i did the gauge swap on my 2016
14-17
17-20
