Tyre pressure Warning symbol Resetting
bob81
Been trying to reset the symbol. Came on first for rear near side wheel is now for rear off side as well. Tyre pressures are OK. Tried following the resetting instructions in the manual but  no luck. Any advice please as to how to do the reset.
Try going to settings  In menu use arrows select TPMS  press ok in and hold in for about 4 or 5 seconds warning light will blink 3 times
After this you need to drive car to initalize.
My system can display tyre pressure in between the speedo and Hybrid system displays.
its 3 clicks down & 4 across on arrow keys on steering wheel.
