Selection of high beam causes light cluster to go off ?
Archangel10000
On the Avensis 2006, drivers side light and dipped headlight are a bit dull......
More concerning is that if I switch to high beam
The drivers side light cluster goes OFF altogether
no illumination at all on drivers side
Passenger side is nicely alight - all good
I took a quick look at the halogen lamp  that does both dipped and full beam - looks ok
tested on pp3 battery  - working
Tomorrow I will check for anything obvious that could be causing disparity
earthing
fuses
relay?
Any thoughts welcome
