Auris 2008 sr180 amp wire through firewall
CH1MPZ
Hi Guys
Planning to feed amp cable through firewall. Anyone here know where the best easiest place to feed the cable? Thanks
There are few places that existing wiring goes through and these are the best spots. You may want to remove glove box to look around or look under steering wheel.
Good luck
Passenger side is a large grommet next to the main loom (its up fairly high behind the G/B
  • Like 3
These also can be seen from outside under bonnet. Auris a bit awkward to work at this place unless you remove the wipers gutter but this looks accessible. image.thumb.jpeg.61d3d1fa8d3940baf409f60c54815703.jpeg
Following your suggestions it was a success. Thanks a lot guys 🤘
