Identify part number or name
tyeardley
Hi all, I’ve recently bought a RAV4 (2016 business edition) which is in great condition with the exception of the interior door handle trims (not sure what the correct term is).
So I’m hoping to find replacement parts for both rear doors, can anyone help identify the part number or correct name, or even better where to find them?
Many thanks in advance.
These parts will be dealer only or perhaps used from eBay or similar.
Door handle garnish or similarly called. You can remove from the car carefully, sand them and re spray with spray paint as diy project and cheapest way.
Official name is door assist grip cover
LH 74646-42060-xx
RH 74645-42060-xx
xx is either B1 (silver) or B2 (smoke silver)
used will be complete with door card (30-50 each), new the trims will be expensive (£45-60 each)
Thank you both, much appreciated.
I’m awaiting info from my local Toyota dealer, but if these are silly prices I’ll give it a try spraying them. I’m not 100% sure if my trim is classed at Silver or Smoke Silver. Is there a way to check online?
to me looks like smoke silver but who knows, it might be just silver.
Perhaps there will be identification on the rear of the panel , next to the part number or on a separate labels, paper label etc. Of you Google the numbers comes up results mainly from Russian sites but still not sure which colour is exactly.  https://euroauto.ru/part/new/2969544/?used_id=22147547
Pop the trim off and look at the part number (usually moulded in to the plastic) on the back, is looks like the standard silver to me
paint, vinyl wrap or upholster them
https://www.mdpsupplies.co.uk/
3m Di-noc is good quality but not cheap you can pick up off cuts fairly inexpensively
Hi, seriously re paint them both ( or all 4 ) wet and dry sand paper and a can of primer then silver auto paint ( look in B & M  or Homestore. ) you will do the whole job for well under £20.00.
Easy and very rewarding.
Terry
