Dealer options 'switch on'
michaelrowell
The manual informs that there are dealer options that can be turned on, for example: closing the windows via the key fob'  Is there a DIY method?
That's the first thing I got the dealer to do when collecting the car. Tech stream/Carly/carista.
Michael, probably buy you would probably need an OBD controller.
I like this feature although mines not been enabled, had it on my Ford but never really used it that much, I’m in two minds to ask the dealer to do it, I much prefer the idea of being able to turn on the air con remotely…
I got dealer to do mine after leaving windows open and having to unlock car and put in ready mode before you can close them.
Carista and a cheap Amazon OBD adapter gives you lots of options you can change.  Check out Carista website and you can look up your car and see what you can change.
I did window open close on the remote, indicator 5 flashes instead of three and a couple of others.
