2008 2.2 D4D bad diesel knock
Mr Wagyu
Hi guys,
I'm new here and have an 08 2.2 d4d xtr thats done 158k and love it.
I've owned it for nearly 12 months and it's always had a bit of a fuel/top end rattle. It started throwing out heavy black smoke and occasionly missing slightly on acceleration.
It failed it's MOT on emissions and showed a P0400 code. I replaced the EGR valve, MAF sensor, fuel filter, air filter and cleaned out the choked up inlet manifold and it passed MOT with no advisories!
However, the fuel/top end knocking has got a lot worse and it's sometimes sluggish with a puff of smoke when it kicks in again. There are no errors or codes showing on my cheap reader, and the check engine/4x4/vsc is not popping up.
Before I try to take out the injectors for testing, I thought id ask if any Rav veterans on here knew of any other causes.
Any advice would be greatly appreciated.
Thanks 👍
