Cooling System Problem
nobbe2556
Here's the deal, I have a '91 V6 DX Camry (2VZ-FE). it recently overheated and since has a problem holding a steady amount of coolant in the reservoir. It always stays just above low. Possibly a leak in the reservoir? Radiator?
thanks in advance.
if either of the 2 were leaking dont you think it would empty completely , check your dipstick and oil filler cap for moisture its possible the head gasket was damaged during the overheating. :thumbsup:
Head gaskets are fine. I put put some JBweld on the radiator cap neck and it seems to have correctud the problem.
