Pruis mk 2 underseal repair
Wildcat54
Hi My Prius mk2 has notifications of rust in various places, are there do's and don'ts to undersealing with  waxoyl underseal on a Prius?. cheers bert.
You need to see the underside of the vehicle really. There are some self service garages around the country that hire ramps by the hour or you could use jackstands but you really need to gauge the level of corrosion for the full underbody and suspension.
Depending on the severity you could apply a rust converter to really bad areas then put waxoyl or similar product over the top. If it is minor and just surface rust I would simply apply waxoyl and forget the rust converter, you can use an aerosol or brush on. Would not apply underseal over the top of rust as from experience the rust will simply continue to worsen underneath the underseal product.
Robert.
You can use Hammerite with or without rust converter.
Waxyl oil can use if you prefer.
Whatever you use check it every year for deteriation.
Hammerite seals in the rust and does not kill it. A reasonable product have used it on suspension items. It will need two coats of applying to a rusted area. The surface must be absolutely clean or it will flake off after a matter of months. Also stone chips will impact the protection hammerite gives, have had more success with other products.
You can nutrilise the rust with a rust eater product like Rust Beater, or Kurust that just two products.
You can also use a stone chip paint.
Waxyi oil it can trap water under it then it ballons that not good if you dont keep a look out for it.
Applied Waxoyl to the suspension items of my Mondeo back in 2005, two coats. In over 200k miles never trapped water and was holding up when the vehicle was moved on in 2022. Underseal absolutely can be a water trap but genuine waxoyl did not crack in 17 years.
Waxyi oil,
I be honest I only seen it traped in the area that cars now have a plastic panel on to give more protection.
Hi , thank you for your input good points there, I was more interested in whether there are parts of the vehicle one should not cover ?
Any Rubber part thats directly onto the rubber.
Those parts that get hot like exhaust/disk brake but you can use high temperature paint on them.
i have not been underneath is there any air intakes like on the back seat edge ?
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
