Yaris Hybrid MK3 dash removal
Vins213
Hi, does anyone know if there are screws to remove for the front panel? Or only clips?
I know I have to unmount the pillar trim, remove the speaker and then only clips, right? Obv the airbag and steering wheel also
I can see no screws here: https://motorist-nn.ru/p/627441453-torpedo-dlya-toyota-yaris-p13-553020d180c1/
Why are you removing the dash ?. Yes there are bolts and screws, what do you mean by front panel ?
dash panel=front panel=upper panel in exploded view
the reason is to fix some terrible rattle, I know that the winter season will be a lot crispy
numbers 10 on the bar, right?
