Hi, i have a toyota corolla 2006 hatchback 1.6 vvti.
I need to take off the wheel hub to replace the rear dust covers. The bolts holding the wheel hub are so badly corroded that when taking them off they nearly fell apart. I am still able to tighten them back on but I would like to replace them.
However I am unable to find them anywhere online.  Does anyone know what kind of bolts I need or where to find them?
Ok so Ive tried all but the most obvious one. I called my local toyota dealership and they had them around £24 for 8 bolts so problem solved. Also they had the calliper bracket bolts for £12 for 4 bolts.
So if anyone is looking for them then call your local toyota dealership.
