Hi My name is Steve, can anyone help with my Avensis
Steve 121
Hi People,
in need of help, I have a 2011 Avensis estate, 2.2 di, Automatic, just wont start, i have checked fuel pressure, changed fuel filter, immobiliser is coming off also, changed fuel pressure sensor too??
in advance
Hi Steve, welcome lots of good advice when you need it and always welcome when you give it. I'm sure someone will help you with your Avensis starting problem. Is this something that has just happened or has it happened before. Any warning lights etc.👍
Hi, Thank you,
It has just happened 2 weeks ago, I've had it plugged in and scanned twice, there are no codes present and no lights on either, confused
Hello Steve - welcome to Toyota Owners Club.
Topic moved to the Avensis forum.
Have you checked the Battery and the starter motor . Is the car cranking over or completely dead
11 minutes ago, Bper said:
Have you checked the battery and the starter motor . Is the car cranking over or completely dead
yes both working and turning over fine
8 minutes ago, Bper said:
Hi Steve, you may have tried a few of these but have a look at this link it may help. Take a look at the diagnostic chart down the page it may be helpful to identify the problem.
https://www.700r4transmissionhq.com/toyota-avensis-wont-start/
Thank you i have a basic understanding , but i think it points to the separate immobiliser ECU, as the seems lots for sale on eby?????
Thanks you
So it's crank, no start with no codes. Does it sound like it has compression, anything happen before this problem like a flat Battery and jumpstart
36 minutes ago, flash22 said:
So it's crank, no start with no codes. Does it sound like it has compression, anything happen before this problem like a flat battery and jumpstart
yes crank no start, comp fine, batt fine, just would not start one morning and thats it
Tried a spare key ? Have you had the Battery load tested ? Does the scan tool actually connect to the car, e.g. gives you the vin or live data ?
Hi Steeve, How does an Avensis look like ? I am not familiar with all toyota models.
On 9/7/2023 at 7:53 PM, AurisOwner32 said:
Have you checked ignition coils and spark plugs?
2.2diesel won't have spark plugs.
Glow plugs simply pre-heat things in cold weather. Diesels rely on compression rather than a spark.
Silly me, didn't read the OP properly. 🙈
  • Haha 1
