Auris sr180 2008 Power Windows
CH1MPZ
Has anyone ever managed to activate the power windows with fob key? Press and hold the lock/unlock to open/close all windows using Techstream? Was thinking of doing this. Can it be done?
It was never an option on the UK/euro spec cars, you could try selecting corolla 2008 it may give you other options in TS (manual car select)
  You can do this with a simple module, but the module can be controlled by an alarm system, so you have to install an alarm system as well.
