Boot clips for cargo net / luggage straps
Dazzar
My car has arrived with hole where the cargo net clips should be, turns out they do not come with the icon trim, anyone know of the part numbers or where I can buy them from in the UK.
Hoop = 58460-33020
Bolt = 90119-06A44
@Devon
went to Toyota they do not list them for the Yaris cross are they the same for all
11 hours ago, Dazzar said:
@Devon
Unfortunately you met a parts person who only goes by what the "Computer says" if they use your cars details there will be no part listed as you do not have them. the part numbers I gave are for a Yaris Cross with them from factory ask them to order the part numbers above
  • 3 months later...
Hi, anyone had luck installing these? I have the basic 2023 Yaris Cross model and simply have a closed compartment in place of the four hooks. Would it be enough to open these and install the hoop and bolt in each?
I have fitted these on my Icon mode, , it is very easy, each cover in the boot unscrews and the hooks bolt in, you need the ones with the single hook and not the double one, mine came from a Corolla and fitted fine also the old style C-HR as well.
Check behind the panel for the existence of the fixing holes. One has a nut welded behind it.
On 2/9/2024 at 3:43 PM, Dazzar said:
Did you not buy them from Toyota? Toyota is more expensive actually...
All four will have bolts behind them which is why youneed the clips and bolts, i purchased the set off eBay, as I mentioned , the CHR ones fit as do  the corrolla , it is a real easy job, the current clips you unscrewe do not just pull them off
TOYOTA AURIS MK1 E150 06-12 REAR CHROME BOOT CARGO LUGGAGE TIE DOWN FLOOR HOOK Currently on eBay
not a lot on eBay, look for luggage D Hooks , I wanted Toyota ones but any one with the correct size bolt will do.
Thanks, I removed the covers and found the fixing holes. Bought the parts mentioned here from Toyota (total was ~€60 so I'm sure the third party option works out cheaper).
On 9/5/2023 at 11:50 PM, Devon Aygo said:
Hoop = 58460-33020
Bolt = 90119-06A44
