Air Feed Pipe!
breezer
Right. Anyone whos familiar with the 1L engine!! The pipe going from passenger side headlight into the airbox, i know you can take it off via the bolt at end next to headlight, but how do u disconnect the pipe from the airbox?
It disconnects right next to the airbox coz ya can see it, but jus wana know what i do to get it off, im careful with these things so dont want to damage owt!
cheers ;)
Take off the front of the air box and look inside at where the pipe meets the box. There are two small bits of plastic (you could call them clips but I don't think they would qualify), just push these in and then pull the pipe out - its a tight fit so just give it a good yank!
i had a pipe running from gap in grille area (have to cut a hole) then acroos exhaust manifold directly onto the airbox,
