drivers door window seal catching
corradovr6
Another annoyance - winding the drivers door window up there is a portion in the middle of the window just before it curves down towards the front where the glass seems to get 'stuck' to the door seal and pulls it up instead of just sliding over it.  I've polished the glass, cleaned the seal and sprayed with silicone spray which works for a while but it then catches again.  There doesnt seem to be any misalignment of the frame and the seal looks like it is seated correctly.  I pulled it out and refitted it just to be sure.
Any other suggestions?  Thanks
