Oil pressure sensor location on 2008 Mark 2 Yaris 1.3
Dodge3
New to this forum...can someone advise where the oil pressure sensor is on the engine block and is it an easy change if I need to renew the sender? Thanks.
Oil pressure switch is at the front of the engine timing chain end access from below the car hope it helps.
PS use some sort of support blocks under wheels or axel stands.
