System of navigation Yaris Active 2014
JohnyKir
Hello everyone. I have bought a Toyota Yaris Active 2014. In the touchscreen of my car there is a button of GPS but when I touch it a message says that is not available in this system. Do you know if there is a way to set in my car GPS and how can I make it.
Thank you.
Basically the sat nav module and gps antenna isn't installed - probably an option for when the car was new. The GPS button is a standard fitment and will work when the module is fitted.
All touch and touch2 units in the yaris have the nav button as above your car doesn't have the nav module
I had this exact message on a basic 2023 CHR hire car.
i plugged in my iPhone and enabled car play.
i then pressed the MAP button (i think that is what you are referring to) and it brought up the CarPlay map.
Probably not the same solution in your 2014 but the same symptom.
The yaris didn't get CarPlay until the mk4 (2020)
The rolla and CHR both have the option for built in nav
My Y22 Yaris doesn't have the satnav module, so I added wireless CarPlay module from Aliexpress. Works perfectly with my iPhone 14, Nav button brings up Apple Maps automatically but you can choose Google Maps, Waze etc on the CarPlay screen.  I bought Carlinkit 4 so can confirm it works OK.  Also works in my Mazda MX5 ND
Carlinkit 4 Apple Wireless CarPlay
I use carlinkit 5. Its a little less temperamental
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
