Alloys
vib
Possibly, but hard to know for sure without knowing the rim specs for your car and those rims.
You need to know:
Size (e.g. 15", 21")
Width (e.g. 5.5J, 6J)
PCD (Basically the lug nut/bolt hole pattern e.g. 5x112.5, 4x100 )
ET (How far the wheel sticks out/in from the hub e.g. ET45, ET39)
Centre Bore (e.g. 45)
Thanks! My tyres say 15 and the ad is for 15inch alloys. Sadly this is where my Knowledge ends. I have a 5 lug pattern, but I will ask the seller about the rest, thank you!
VW alloys won't fit the Auris as the bolt pattern and centre bore are different.
Bolt pattern (PCD)
Toyota Auris 5/114.3
Centre bore
Toyota Auris 60.1mm
