Hey guys,
So after my last topic i had issues that my clutch was slipping, couple days later i had it replaced for a new clutch set. The surface of the clutch plate was very worn and the clutch thrust bearing made a grove in the clutch cover of wear, almost cutting out a round circle in the cover. Now it rides perfect for 2days it started to make a rumble/clicking noise during shifting. Is Anyone familiar with this sound or knows what it could be, it does it on every gear change.
I've attached a video so you can hear the sound yourself.
Thanks!
its a 2009 toyota aygo with 125k km's on the odo with MMT box. Drives perfectly with the new clutch only that knocking sound had me worried.
It sounds like it's changing up, it may need the gearbox oil topping off - the garage may have forgot to do it
GL4 or SAE75w
GL4 or SAE75w
Also when riding it does it, went back to the garage they couldn't find anything. we tough it was the motor bushes making clunk sound but wasn't. sound drives me crazy in the morning when it is cold doesn't do it after it warms up it clunks like crazy while riding and always on shifting
Wrong oil in the gear box ??
i don't even know if he changed the gear box oil. i only know he replaced the clutch
