Yaris 2018 spare parts.
spetros1
Hello to all
I would like the spare parts numbers for the motor assy for the air vent selector and the motor assy for the air selection tamper ( inside / outside ) for the automatic clima control
Thank you.
1 hour ago, spetros1 said:
Hello to all
Thank you.
By vent is assume your mean air direction = 87106-0D031 SERVO SUB ASSY, MODE
For recirculation = 87106-0D041 DAMPER SERVO SUB ASSY, BLOWER REGULATION
Hello flash22.
I wanted the parts number because i want to make some tests with them.
Thank you for your answer Devon Aygo
Thank you for your answer Devon Aygo.
I have searched the parts that you send me but is all discontinued. Is it possible ? it is a 5 years old car.
Maybe the part numbers are wrong ?
Thank you
I can confirm the part numbers are correct
what are you trying to do ? Wiring diagrams are not a problem
Hello Bob.
I want to control them with an Arduino so if you have diagrams will be very helpful.
The servo/motors/actuators are all controlled by the AC amplifier, the best point would be to tap the LIN Bus from the controls to the AC amp to interface the Arduino
the motors are all linked with a "bus" power, ground and control and have 3 limit switches each
https://github.com/macchina/LIN/blob/master/examples/Sniffer/Sniffer.ino
https://reference.arduino.cc/reference/en/libraries/linbus_stack/
https://www.macchina.cc/
Thank you Bob for all these information's.  You are AMAZING
Do you know the pinout of the automatic A/C control ? there are 8 pins but i dont know what every pin do
If you know please inform me with the AC amplifier part number ( automatic A/C ) for yaris 2018.
