New member here,so bear with me!!!
My 1994 jap corolla xe needs 2new rear coil springs,so says my mechanic..its a daily runner doing about 10km a a day..
he said he is not able to source them and neither is my local motor factor.....he says I'm on my own with this one!!!
He also mentioned that xli springs won't be suitable either...
Any input greatly appreciated..thnx
you can use these websites to locate your car exact model specs, engine and look for part number.
https://kyb-europe.com/wp-content/uploads/2017/07/KYB-2016-Coil-Spring-Catalogue.pdf
https://www.autodoc.co.uk/spares-search?keyword=KYB r6167&maker_id=111&model_id=151&car_id=3496&sort_categories[0]=188
https://japancars.ru/index.php?route=catalog/toyota
If you can’t do yourself, you can give more information about your car what model is exactly E10 or E90 for example, what is engine size,  transmission type etc and we can look for you.
Can you get the OEM part number for the rear springs from a Toyota parts department?
Having the OEM part number is the best way to find aftermarket parts.
Can you see which Corolla you have in the below list?
  • COROLLA (_E10_) 06.1991 - 11.1999
  • COROLLA (_E11_) 05.1995 - 06.2002
  • COROLLA (_E12_) 01.2001 - 12.2007
  • COROLLA (_E7_) 09.1979 - 09.1985
  • COROLLA (_E8_) 06.1983 - 06.1989
  • COROLLA (_E9_) 05.1987 - 09.1994
  • COROLLA (KE_, TE_) 02.1970 - 11.1981
  • COROLLA Compact (_E10_) 05.1992 - 12.1999
  • COROLLA Compact (_E11_) 04.1997 - 01.2002
  • COROLLA Compact (_E9_) 05.1987 - 10.1995
  • COROLLA Coupe (_E7_) 08.1979 - 07.1983
  • COROLLA Coupe (_E9_) 05.1987 - 10.1995
  • COROLLA Coupe (AE86) 05.1983 - 07.1987
  • COROLLA Coupe (KE) 07.1975 - 12.1982
  • COROLLA Cross (ZVG1_, ZSG1_, MXGH1_, MXGA1_) 07.2020 -
  • COROLLA Estate (_E10_) 09.1991 - 04.1998
  • COROLLA Estate (_E11_) 04.1997 - 10.2001
  • COROLLA Estate (_E12_) 03.2001 - 12.2008
  • COROLLA Estate (_E21_) 02.2019 -
  • COROLLA Estate (_E7_) 12.1979 - 08.1987
  • COROLLA Estate (TE72_) 07.1975 - 07.1982
  • COROLLA FX Compact (E8B) 08.1984 - 05.1988
  • COROLLA Hatchback (_E21_, _EA1_, _EH1_) 10.2018 -
  • COROLLA Hatchback (_E7_) 09.1979 - 09.1983
  • COROLLA Hatchback (KE, TE) 10.1972 - 01.1980
  • COROLLA LEVIN Coupe (_E10_) 06.1991 - 08.1997
  • COROLLA LEVIN Coupe (_E11_) 05.1995 - 07.2000
  • COROLLA LEVIN Coupe (E9_) 05.1989 - 05.1991
  • COROLLA Liftback (_E10_) 05.1992 - 12.1999
  • COROLLA Liftback (_E11_) 04.1997 - 01.2002
  • COROLLA Liftback (_E8_) 05.1982 - 05.1989
  • COROLLA Liftback (_E9_) 05.1987 - 04.1997
  • COROLLA Saloon (_E12_) 08.2000 - 12.2008
  • COROLLA Saloon (_E15_) 10.2006 -
  • COROLLA Saloon (_E18_, ZRE1_) 06.2013 - 08.2019
  • COROLLA Saloon (_E21_) 01.2019 -
  • COROLLA Station Wagon (_E9_) 05.1987 - 10.1995
  • COROLLA Verso (_E12_) 07.2001 - 05.2007
  • COROLLA Verso (ZER_, ZZE12_, R1_) 03.2004 - 04.2009
Have a look at wikipedia for help with identifying exactly what car you have. When choosing springs, things such as engine, body style and number of doors, automatic or manual gearbox, factory fitted towbar, can all affect the choice of springs.
Toyota Corolla
https://en.wikipedia.org/wiki/Toyota_Corolla
Toyota Corolla Seventh Generation E100
https://en.wikipedia.org/wiki/Toyota_Corolla_(E100)
1498 cc ae100. 5AFE, just incase the image is not too clear...thnx in advance for the help!!
What body style is it? There were lots of styles such as 2-door, 3-door, 4-door, 5-door, liftback, estate, coupe, saloon, etc
4 door saloon ...thnx....
The below Kilen 64280 might fit. However, it's best to check the OEM part number to check it's either 482311E090, 482311E200, or 4823102120...which is what the Kilen 64280 is sold to replace.
You can compare the specification of your current springs, such as wire thickness, length, etc. with the specification below...but it's going to be easier and more accurate to find the OEM part number of your original rear springs.
KILEN 64280 Coil Spring for TOYOTA COROLLA Rear Axle, Coil Spring
  • TOYOTA Corolla VII Compact (E100) (Year of Construction 07.1992 - 04.1997, 72 - 114 PS, Petrol)
  • TOYOTA Corolla VII Liftback (E100) (Year of Construction 07.1992 - 04.1997, 72 - 114 PS, Petrol)
  • TOYOTA Corolla VII Saloon (E100) (Year of Construction 05.1992 - 04.1997, 72 - 115 PS, Petrol)
Spring Design Coil spring with constant wire diameter
Fitting Position Rear Axle
Thickness 11.25 mm
Length 342 mm
Outer Diameter 109 mm
Outer Diameter 1 151 mm
Weight 1.75 kg
Kilen 64280 (sold to replace 482311E090 482311E200 4823102120)
https://www.autodoc.co.uk/kilen/7837830?search=KILEN Coil Spring (64280)
https://www.ebay.co.uk/itm/143320063665
KYB RI6167 (similar to Kilen 64280)
https://www.autodoc.co.uk/kyb/832218?search=KYB Coil Spring (RI6167)
https://www.ebay.co.uk/itm/304720448258
  • Like 3
Thnx very much ....will check it out !!
KYB from either eBay or auto doc will be my choice, and replace both sides. 👍
Can you PM me your full Frame number
this is a JDM car, part cars vary greatly to their euro counterparts
Its a JDM car
Built - 04/1994
Model - AE100-AEMNK
5AFE, 4 door sedan, 5 speed manual, XE in 3K9 (light taupe)
Spring - 48231-1E250 70-120 each plus shipping from japan
https://www.amayama.com/en/part/toyota/482311e250
oddly enough, the shipping to Ireland is half the cost than to the uk
Thickness 11.25 mm
Length 342 mm
Weight 1.75 kg
Kilen 64280 listed on ebay
Thanks very much for the help!!! Very daunting when I don't know much about "under the bonnet"so to speak !!!
Thnx again all!!
Just pulled up an old KYB catalogue
and they cross-reference
48231-1E580
48231-1E090
48231-1E260
48231-1E250
KYB RI6167
55 minutes ago, flash22 said:
Its a JDM car
Built - 04/1994
Model - AE100-AEMNK
KYB RK9660 is sold to replace 48231-1E090, 48231-1E250, 48231-1E260, 48231-1E580, so Kilen 64280 and KYB RI6167 should be similar to 48231-1E250.
KYB RK9660 is not supplied by KYB in Europe.
I'm aware of these facts, just following the breadcrumbs, and confirmed the cross-ref
KYB RK9660 is the equivalent to a rough road package spring
I've used Amayama before.
48231-1E580
48231-1E090
48231-1E260
48231-1E250
KYB RI6167
I can get the kyb ri6167 for 44€ each online ...probably the cheapest option if they suffice....
KYB are usually the oem supplier to Toyota for  springs and shock absorbers.
I have changed my rear springs last year and I bought KYB from Auto doc, they perfectly matched the original ones by specs and sizes and were easy job replacement as diy. If you buy original Toyota they night be KYB inside the box.
i have triple checked the cross reference
If you look at the KYB 2022 spring catalogue, it shows that KYB Europe only supply two rear springs for all models of the Corolla E10...RI6166 and RI6167.
The RI6167 is for the estate versions of the Corolla E10 whether it's the 1.3 petrol, 1.6 petrol, or 2.0 diesel engine.
The RI6166 is for all other versions of the Corolla E10, again whatever the engine version.
So if you want a KYB Europe rear spring for your Corolla E10 you are limited to these two rear springs...and I wouldn't recommend the estate rear spring if you don't have an estate...as they tend to be stiffer. If you fit the estate version, not only is the rear spring likely to be too stiff but the rear of your car is likely to be too high.
Working out the front spring is just as easy, as again KYB Europe only lists two different front springs for the Corolla E10...RA3759 and RA1239.
RA3759 is for the 1.3 petrol and 1.6 petrol engines...whatever the body style...so including the estate.
RA1239 is for the heavier 2.0 diesel engine...again whatever the body style.
Because yours is a 1.5 petrol engine, it makes sense to use the 1.3 and 1.6 petrol engined front spring.
Of course, it is also best to check against your OEM part number like you did with your rear spring...just in case there's a surprising difference between the European and Japanese Corolla E10 versions, or KYB have got it wrong in their catalogue.
KYB spring catalogue 2022
https://kyb-europe.com/wp-content/uploads/2022/06/KYB-Coil-Spring-Catalogue-2022-Version-A-ENG.pdf
Thanks again all !!! For the advice
