Mk1 Japanese Yaris, no working keys
Melliwuk
Hi all, got a bit of an unusual one here:  I will apologise in advance for the long post...
I was doing some welding on my Yaris, for some reason all the voltage seemed to shoot through the whole electrical system.  As a result my ECU went up in smoke, blew out all the diodes and damaged the Eeprom that holds the key codes.
I have sourced a second hand ECU but obviously the key transponder codes are different to my key ( i only got one with the car btw).  i have read the transponder code with a mini-bull reader (yes i get the Tiris data with windows, not just the main data you get when using it on its own).  I have 2 Eeprom readers that support the Atmel 25020 Eeprom which is in the ECU, however when i try reading with both readers it only reads the first half of the data in the chip.
So my problem is that even though i know the Tiris data i need to program into the chip it wont write the second part of the data
The part where the key data is stored, this part i can read and write.  But i have a feeling that if i write this then the second half of the data will be erased during writing this part.  also as you can see there are already 6 keys stored in this data, i am wondering if i wrote the Tiris data for one of these keys to the transponder in the key if that would solve the problem and allow the immobilizer to turn off...  (split into 16 byte lines for easier reading lol)
The Eeprom readers i have are a ch341a and an ezp2019 usb spi programmer.  both read the first half of the data when set to the Atmel 25020 but not the second half.  i am wondering if maybe Toyota had a special version of this chip made...  i have just noticed that the Youtube guy had the chip selected as a 25040 but when i tried that it just got blank data or repeated the first half of the data again...
I am wondering if i take the Tiris data from my ECU and write it to the transponder of my key if maybe that would work?  When reading the ECU i get unmatched key code error code, so the imobiliser is clearly reading the transponder.
Sorry for the long post, but i have been fighting with this since may and really need input now, as i don't want to rewrite the data in my key transponder unless it's likely to work...
Thanks for reading 🙂
Melli.
TBH, you're better off getting the keys and locks for that replacement ECU and just swapping them all over (Or, if they're not available, sending it back and getting them to swap it for an ECU that has all those bits, mainly the functioning keys, door locks and ignition barrel)
That said, flash22 might have the address the transponder codes are stored on the eeprom that you might be able to manually change, but that level of hackery is beyond me!
IIRC the immobilizer is part of the receiver ring on the xp10
what make are the keys, Valeo or Tokai Rika ?
What's the part number on the ecu ? Is the used one also from a jap car with the same P/No.
I have a few different tools I use
This might help, but as above might be cheaper/easier to grab another ecu with matching key.
Can you send me a dump of the atmel and 4d chip info
edit. Pull the atmel off the old ecu and fit it to the new ??
 when the ecu blew it blew out one of the legs on the chip, i did manage to get a dump of it, but i think it's only half the data, but i will attach what i got.  i have since managed to loose that chip somehow...  so using the original chip is no longer an option.   as mentioned above, with the eeprom readers i have i only get half the data from the atmel 25020 so i dont know if that would help, but i will attach what i have.  i will also get a dump of the replacment ecu chip and attach that in a seperate post.  but i have a feeling i may need a different eeprom reader/writer.
the first key, 36 72 90 05 is the key i have.  i will hook up the zbull and get a dump of all the key data shortly too.
yaris.bin
On 9/27/2023 at 2:04 PM, flash22 said:
After a few technical difficulties
i have read that dump, after a bit of trial and error it comes back as an 4C
give this a try
yaris mod1.bin 512 B · 0 downloads
yaris mod 256.bin 256 B · 0 downloads
thnaks for that flash, sorry i forgot to say it's a 4c transponder...  i havent managed to get a key dump yet as for some reason my z-bull mini has decided to stop communicating with my pc, i will sort that if need be.  i will flash that as soon as i get a chance, got major repairs to do to my working car atm so will get round to the yaris after.
as soon as i get a chance to flash that i will let you know what happens.  i assume its the 256 byte file i try?  or do i try the 512 byte one first and if that fails to flash try the 256 byte one?
thanks, melli.
Only difference is the second part of the 512 of the hex is FF, as the data is in the first 256 and the immo only needs to read the first 256 it all depends on the software you use
  • 1 year later...
sorry for the long wait for this update, basically i couldn't get anywhere and was getting really frustrated and left the car alone for almost a year...  started tinkering with it a few weeks ago, had a lot of trouble reading and writing the chip...   also had to buy new keys and locks as i managed to loose the original key!  changed the ingnition barrel over so the original key no longer turns the barrel.
a while after changing barrels over i found the original key but cant use the old barrel as it got damaged while removing it.  today i went out there and managed to read and write the chip successfully so i experimented with the key data i had for the old key, i had to remove the ring from the barrel so i could put the old key inside it to read the chip.  i managed to figure out the way that the key data is stored in the ecu.
basicaly if the key data reads as 12 34 56 78 then you put it in as 78 56 34 12 if i remember correctly.  anyway, now i have the key data in there i can use the old key in the ring while using the new key in the barrel to turn it and disable the immobiliser.  so hopefully this will allow the car to start now, just got a few bits to put back on the car and put some fuel in it then hopefully it will start 🙂  i will update when i get to that point if it works or not.
thanks go to Flash22 and Iani100 the video ian linked was invaluable, that was what allowed ne to figure out the order the tiris data goes in.
