Corolla 2003 with a Frozen clusting crying out for help
I have a 2003 Corolla Hatch. Last week I was driving my car when suddenly the guage cluster froze and the light illuminating the cluster turned off. 10 mins later a 'P/S' indicator turned on. So now I have a gauge cluster with all dials frozen in random positions, the back light not turning on and a red P/S indicator illuminate. The P/S stand for power steering because my steering also became a little heavier. So the question I have. Is the cluster broken or is it trying to indicate to me that the power steering has gone and it needs to be changes. I say this because about 10 years ago something very similar happened when I got the same frozen cluster. I paid a garage to diagnose the issue but they found nothing. In the end I found the issue to be a warned out back brake. So do you think it is the same scenario?
If you have an OBD2 scanner might be worth plugging that in  to see if any relevant Error codes have been generated by the PS light /fault,  though some sites say a standard scanner will not pick such codes up and you need a more capable device.
Disconnecting the Battery for a few minutes might clear the fault ( as well as clearing any stored error codes)  or  if the fault returns after reconnecting the Battery you will know its a more likely a hard fault.
Assume yours is an Electric power steering system ?
