Toyota Estima 2004 2.4 4wd auto windscreen washer fuse
Hi all.
Can anyone out there help. I've searched everywhere on the car, but cannot find the windscreen washer pump fuse.
I've looked in the handbook, checked diagrams on the web, but nothing seems to point for sure where I can find this fuse.
Had a wire come loose from the new pump I had fitted, secured the wire, but as it still doesn’t work, I want to rule out the fuse before I take the pump back.
If anyone has the same car as mine, and knows for sure where I can find this fuse, I'll sleep happier tonight!
Thanks in advance for your input guys.
Graham
AFAIK ther are only 3 locations possible...1 under the bonnet near the bulkhead and one box each behind the side trim/kick panels in each of the passenger and driver footwells. (not easy to access)
Thanks very much Neil. I've checked these 3 locations, and yes, the interior boxes are a swine to get at, which is why I thought if anyone knew exactly which side the fuse for the washer pump was it would be half the battle, don't want to start pulling panels off and poking about unnecessarily. I've checked all the fuses under the front, so believe it's not there
