Door and Window controls.
James 1960
The door locks are working perfectly from the fob and the handle receiver but not the master switch. I can only put the drivers window down from the drivers switch and the door lack button does not work either. I have replaced the master switch and tried resetting it but to no avail. I do not see any problems with the wiring or the controller but I have not replaced it yet since I do not want to keep throwing parts at it. Any ideas?
They are 2 systems, 2009 T270 ?
Disconnect the Battery for 15-20 mins and let it reset
Do the windows work by their switches on each door ?
do the doors all unlock/lock by the physical key in the drivers door ?
It does unlock all the doors with the physical key and each door switch does work it's window. I will try unhooking the Battery in the daylight tomorrow. It is a t270 saloon.
I just tried disconnecting the Battery for 15-20 but it made no difference whatsoever. The door locks all work with the fob and the sensor on the handle but not the master switch. it does not lock or unlock. I have replaced the master switch but it did the same thing.
It's a broken wire(s) in the loom, more than likely in the bellows between the car and the door the insulation stays intact but the cores snap
