Yaris Hybrid 2014 floor mat clips missing?
KCYH2014
Hello,
New to owning a car, so apologies if I’m being thick. I’ve bought some floor mats for my Yaris Hybrid but there doesn’t seem to be any clips in my car (please see images).
It looks like something has been there at some point and there are two holes at a 90 degree angle to the floor, beneath the drivers seat. I’ve tried searching for something that might fit but can’t seem to find anything. Does anyone know what part I need or what I should do?
Many thanks
if you buy original Toyota carpet mats likely they come with a new set of these hooks, if not then you can try to find them from your local dealer or eBay . Best to buy original but also aftermarket can do it.
It seems the previous owner has them misplaced.
Good luck
2 minutes ago, TonyHSD said:
Good luck
Thank you. I have tried to look online, but I can’t find any clips/hooks that look like they would fit in those holes under the seats and sit flat on the floor. They almost need to be an L shaped fixture?
8 minutes ago, flash22 said:
But where does this fit? There’s no holes in the floor to put them into? The only holes I have are slightly off the floor on the drivers seat?
3 minutes ago, flash22 said:
That's correct, is it a facelift car ?
i will take a pic shortly
I’ve no idea sorry - would that mean it could have had new flooring put in without the clips? In which case could I just buy universal clips that screw into the flooring?
It's the same as mine, it uses the L shape clips with twist locks from factory
58522-52030 looks like dealer only
the hook type ones just hook over the edge of the carpet
Thank you so much, at least I know what I’m looking for now! 😊
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
