Hi everyone
I have a little problem with my Toyota Corolla 2005 model.
There is a frequent noise comes from internal ventilator (on right side of cabin).
I have upload two short videos in order to avoid descriptions like tsik-tsik pik-pok ghrt-ghrt
https://we.tl/t-UBFIlXl4uM
If anyone has the same problem at the past and solved it is very welcome.
Thanks in advance Theo
Sounds like you have a twig or something caught in the fan.
Good idea. I will open it to check.
But my query is why I cannot hear it while vedilator is on ?
It happens occasionally without a reason.
Anyway, I will try to see if something is trapped in there.
Thanks a lot
I had a leaf stuck in my first Mk1's vent somewhere when I first got it (Not surprising since there the spare-wheel well was full of sand and garden waste! And this was a used-approved car too!); Most of the time it'd be fine, but occasionally it'd vibrate and make a sound like a very annoying kazoo!
Eventually, between the AC and heater drying it out, I assume it got so brittle it just disintegrated as it stopped doing it after a while.
