How do I open my key?
waqy
Hi everyone,
Recently picked up an Auris, but the flip spring in the key fob has lost its tension and won't flip anymore.
How do I open the key fob? I've only managed to remove the back and access the battey part.
Key is the following:
[img]https://i.imgur.com/zDXgi5r.png[/img]
Thanks!
iirc it's just clipped together, it's the same as popping the Battery cover off just split it at the seam
if it does not feel like it's going to move, it may have a screw under the Toyota logo on the back heat it and the logo should peel off
  • Like 3
44 minutes ago, flash22 said:
iirc it's just clipped together, it's the same as popping the battery cover off just split it at the seam
Cheers!
There was a screw behind the logo, which was why it wasn't budging!
Managed to pry the logo off and got to it.
