Seeking drive shafts for Mk 1 Yaris
Damien McManus
Good evening, I posted here in July about my Yaris having ABS issues at low speeds. I think I finally got the problem diagnosed as worn reluctor rings from an electrical specialist, and was advised to get driveshafts on each side replaced by my local garage. No-one seems to be able to supply these at the moment so I would be really grateful for any advice on how to get my hands on some. Not really keen to go down the eBay route, would rather buy new.
Talking via PM, it could be corrosion, cracked in the reluctor and/or crushing/rust jacking of the sensor
tbh it's a case of taking it apart and having a look, wheel off, break the CV nut loose - split the lower joint, unplug the abs sensor
