Avensis electronic parking brake
Bladerr6
16 hours ago, SB1500 said:
Hope this helps in regards to a clear description of how the system works, as well as instructions on turning on the ‘auto’ mode 😊
As I keep saying, the auto function is for automatic application of the EPB. It does not control the automatic release function, which should be operational at all times and cannot be disabled.
  • 9 months later...
On 10/8/2023 at 11:43 PM, Derek.w said:
Note it will disangate from automatic function with accelerator if held down in its disengaged position for to long before you release the switch
Hi
Do you know how On avensis T27 to do Full Release Mode for brake.  Maintenance Mode for service brake pads ?
On 10/9/2023 at 4:09 PM, Cessna said:
You can hold the EPB button for 5 seconds to enable and disable the automatic application of the EPB, but it does not affect the automatic release of the EPB.
HI
in the manual is written, that you can switch off/on automatic apply operation for brake,  for manual transition. read with attention again.
On 10/10/2023 at 12:04 AM, Cessna said:
but Matt is talking about the automatic release of the EPB
yes. to enable auto release (when you press gas pedal) first need to enable auto mode by hold 8 sec
That is incorrect. As I said above, the auto function is for automatic application of the EPB only. It does not control the automatic release function, which should be operational at all times and cannot be disabled.
yes. but we can swtch on or off this function.
by default on MT it 's enabled. if you want to maintenance for example break pads you need to disable auto parking mode. but this is not the service mode.
if auto parking is on then 1st gear and gas and will be automatic release the pads
You seem to repeated what I said using different words, but that is fine!
