Abs sensor 92' GTI
burakk388
I am looking for solutions for my celica 92' cabrio GTi. As the abs sensor cable is broken and am not able to find another one. Is there a known solution for this.
Thank you
If you can see where it is broken, cut 20mm of wire from both sides of the broken area and then solder a new 40mm piece in its place.
It is also quite common for the sensor unit to fail, but it is possible to modify a sensor from a Lexus ES350 (2006-2011) so that it will fit.
sensor-002.jpg.9a45e6e7ed3ab5a51c291afe55c4b4c1.jpg sensor-001.JPG.669e4e50bc9cb8689d9a546cad83bb7b.JPG
You will need to reuse the original connector plugs at the end of the wiring harness and the original bracket.
