A R G H
vmail
is the courtsey light, LCD Dash, radio, remote c/lock on the same circuit
none of them are working
only the 10A ones, will check the rest later
I dont think the c/lock is faulty, I think the car is being tricked to think that the door is open so thats why I cant lock it or arm the alarm
it only shows the fuse box locations
No.
The fuse for the door locks is a 25A called D/L, it's in the under dashboard fusebox.
Fuse for the others are 15A DOME (engine compartment) for interior light, LCD and radio and 15A ACC (under dashboard) for LCD and radio.
Cheers, Yves.
Edited by yvvan
I had this problem, in the fuse box below the steering wheel, If you replace the SECOUND from BOTTOM fuse in the most LEFT coloum, you should be sorted!
Cheers
matt
cheers matt will look into it
it might of happen when I tryed to fit my 9LED xenon white courtsey light
Btw, when you get the fuse, make sure its the MINI blade fuse....
and its 15 amps if i remember correctly
Cheers
cheers, I why did Mr T have to use the mini ones, they cost too much
thats only 1 though, I can only buy in packs of 3 or 5's
wouldnt say expensive rtho as it gets you lcd, headunit, cig lighter working all in one!
normal one are only 10p each
cig light should work, my cathodes are on that circuit and they work
hhmm, well when i blew it, my lcd, my heaqdunit and my cig power went, i wonder if phase 1 circuity is different ??
or maybe my cathodes are running on the ignition, dunno now, Ill have to check it
do you know which TOC member has got a led courtsey light, tryed using the search but not got any results
did he have the neons in the air vents aswell?
i had dat problem....it was 1 a da 15amp fuses, think it was second one up from the left side of the fuse box on inside of da car.
Yep thats what i sed!
Youv just confirmed it mate :thumbsup:
found it, it was a 15A fuse in the main fuse box labled DOME, and I blew it again, so I taped up that stupid metal thing, is it ok to stick a 10A fuse for a bit
If u could use a 10A fuse it would say 10A...
So the answer is NO........Don't even try it
its doing the job, will replace it on Monday
