Tailgate struts where to buy- K reg 1993 Estima
Does anyone know where I can buy replacement tailgate struts for a 1993 (K reg) imported Estima. I can't find the OEM on the current struts. I would buy aftermarket ones but don't even know what length or load weight to look for. Can anyone help please ?
Try Gary at GT Motors, Newton Abbot, Devon.
https://www.gtmotors.co.uk/
Thanks for the link. I've e.mailed them so fingers crossed.
1993 should be the same as a previa, PM me your frame number
68908-28070
68907-28070
the number should be on the struts 620mm
68908-28070
68907-28070
PM sent - thanks.
Posted (edited)
I've located some Quinton Hazell struts that say they are direct replacements for those numbers, but then it says it's not compatible with my vehicle. So stuck again - what a nightmare!
https://www.bestpartstore.co.uk/11960127-quinton-hazell-tailgate-strut
https://www.arnoldclarkautoparts.com/products/qh-gas-spring-boot-strut-qts840286
Edited by MikeGB
added links
EU spares are part of the German car part mafia aka autodoc
the part numbers above are uk/eu spec Previa
JDM spec Estima by your frame number are
RH - 68907-28031
LH - 68908-28031
can you post a pic of what you have now, just to make sure no cables come out the top of them ?
