Hi all. I recently aquired a 1992 Surf 2.4TD that had a meltdown of the wiring harness from the drivers side door switch panel. the switch assembly and harness have been replaced but still not operational. I have been unable to get my hands on a wiring diagram for this vehicle. 2 wires in the vehicles main harnesses from this switch unit have some heat damage, one I assume is an earth wire (black/yellow stripe) the other  (Blue/red stripe) I feel that the Blue wire should supply power to the switch, but it does not and I need to know where it's power is fed from. also where I could get my hands on a wiring diagram for this vehicle. I'm also told it is an import. Thanks in advance.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
