Desperately seeking a fuel pump unit that sits inside the fuel tank (under back seat) if my Corolla (year 2000) the part no is
Bosche 0580313058
as mine is leaking.  See image.
please email me
catbray@hotmail.com
Oem number is 77240-02050 and is a 2 year only part - Discontinued
what part is leaking, is it cracked or has the o-ring gone in the quick disconnect ? is that part number from the one on the car
Yes we are having trouble replacing it. Hence reaching out in this forum.
According to my mechanic it has a has a hairline crack which is allowing fuel leak and making my car stink.
my mechanic has glued it which helped for a bit but it’s leaking again .
The only thing that spring to mind is using a bulkhead fitting, but you will need to know the size of the QD fitting and the size of the flexible pipe inside the pump
Thank you very much. I will pass that to my mechanic
Sent you email earlier.👍
