My Aygo Automatic clutch is slipping badly and probably needs replacing.
what is likely cost and best source for repair as don’t trust Toyota dealer!
Many thanks
Jonathan
If you can find someone that will touch a MMT £650-£850, a main stealer will want to do clutch, both actuators and possible clutch fork and MMT ecu if they have never been done
don't be surprised that you need the clutch actuator
INF12215_GB.pdfCP-0009T-0113-EN (2).pdf
I had my 2012 clutch done 18 months ago  it cost me £210 that was cardiff area .
They told me it was £180 but when I went to collect it he upped the price to around £250 but I had the card with the cost on it  so he reduced it to £210 and said he had to do extra work to free up parts that was rusted /stuck . Also he supplied the clutch  .
he asked if i wanted yaris clutch fitted as he said it's better than aygo one   but I said aygo as I don't know not sure if I did right or not .
The bigger Yaris clutch was standardised in the Aygo from early 2009 ......
Hi  oo so I might messed up then by saying I wanted the aygo one .bugger well I'm sure once iv finished teaching the kids how to drive  (two just waiting on dates for test.. 4 month waiting list here in cardiff ) then I have to teach my oldest then  so I guess I need a new clutch again .so it be the yaris one  then .
For clarity - is your car a manual or MMT?
That will be a for a clutch kit on a manual
no such thing as a yaris clutch for an Aygo, 95% of clutches on the market are 190mm
https://www.partinfo.co.uk/files/Technical bulletin 077 - Toyota Yaris.pdf
the yaris from 2008 iirc use a 200mm clutch, before that it used the 190mm, Mk2 Aygo Uses a 200mm
the MMT is a bit more complex you can't just pull the box and slap in a clutch you have to follow the process, a lot of places will not touch them as they can be a pita
The 2005-2009 Aygo/C1/107 used a 180mm clutch, and from early 2009 the larger 190mm clutch used by the Yaris was standardised in production.
