P0171 bank 1 lean condition. Car running rich poor Mileage
I'll check the PCV valve and see if it's blowing both ways will update
1 hour ago, flash22 said:
ltft show a major vacuum leak, have you tested the PCV valve it should only work in one direction, why parts from Japan most parts are still available over here
Any possibility u can send me link where to buy from
It depends on what you require, many manufactures share parts across cars, usually I look up the OEM part number and go from there
Looks like if found that faulty ordering these
You don't need the hoses unless they are cracked or perished
Changed the PCV valve 😔 LTFT still the same high
Question. I took for the MAF plug and started the engine my OBD still showing the MAF READING 0.3GS is that normal
It's probably gone into default to mode to keep the engine running, as in a limp home situation.
TBH, if you wish to carry on with self diagnosis your best time will be spent on Google, YouTube or maybe try one of the American sites as I don't think too many folk on here are diagnostic experts.
Update : after changing pcv I drove more then 100 miles No engine light came up and only one point down 😁 b4 it only take 20-30 miles to pop in on my dash looks like we got the culprit
Good news for your endeavours and a good call by Flash22 for suggesting the PCV👍
He guys I am changing the valve cover gasket and transmission oil and filter can I please know if someone have the torque specs for 10mm transmission pan bolts and valve cover bolts
