Any help appreciated here, this is doing my nut in!
If I add the tyre pressure to one of the layouts on the multi information display, it loses the setting when I power off, and reverts to displaying the Energy Monitor next time I power on...
Am I missing something here?
Before power off 👇IMG_20231026_1552082.thumb.jpg.eea56b3b98ec97b0911ac3f08ce749bc.jpg
After power off and back on 👇 IMG_20231026_1552572.thumb.jpg.c2e0bc4e4c4ee16f608af8320ca8ea5c.jpg
Thanks very much for that Bob, I did suspect an issue, so at least I know it's not just me! Toyota CS have been as helpful as a chocolate teapot when I raised it with them... 🙄
Are you saving the changed layout in your driver profile?
Yes I am. Tyre pressure is the only function that won't remain saved, everything else saves to the driver profile without any problem.
That's me out of ideas I'm afraid, although I would question why you want the tyre pressures displayed all the time. Once set, there would be a warning if pressure dropped in any wheel.
It's not a case of wanting it displayed all the time. I tend to only use 1 of the 3 display screens, so having the tyre pressure available on 1 of the other 2 screens when I want to check it, would be nice. Instead of having to go in each time to change one of the existing settings just to see the pressure.
From the manual - "The tire pressure warning system does not replace routine tire inflation pressure checks. Make sure to check tire inflation pressure as part of your routine of daily vehicle checks."
Same problem for me too. Have to reset everytime. No big deal really but I hope Toyota do fix it at some point in the future.
same here, in contact with toyota about that.
