Suspension noice and clunking 2009 T27 D4D automatic.
Herman H
Hi everyone,
Since shops only tell me to try this and that (parts cannon alert), I turn to the community.
Can somebody tell me what is wrong?
Driving over uneven terrain is clonky (yes, maybe sway bar and or bushings), I have some play in the steering wheel, makes noice too, and when I from park to either drive or revers it sounds like I smash two glass bottles together.
Anyone?
Thanks in advance.
you can start with this: buy 1 can of silicon spray or WD40, go under the car and spray on all the rubber joints that you can see + open the hood and also do so + suspension upper mount:
if it wont help then it can be 4 things:
sway bar holder, sway bar end, sway bar bushing, suspension upper mount.
each of them make huge notable different when you put a new fresh part.
i would change them all.
That to me sounds like you have the car in gear and the exhaust coupling is making that noise when the engine/gearbox moves. How about you get some one to help you locate and pinpoint it?
