Aygo X 2023 CVT cruise control to/from 0 or to/from 16 mph ?
I am thinking to buy the Aygo X CVT (Automatic). Any owner knows, if it is possible to set that the Adaptive Cruise Control (ACC) goes, "to and from" zero?. really usefull in traffic jams.... ;-).  The manual version, that i have tested, disconnect at 16 mph...
I can't say specifically for the AygoX but my Mk4 Yaris will go down to 0mph on the radar cruise control - I abuse it in stop start traffic sometimes when I get bored :laugh:
It does ride the brake a lot below 5mph tho
I don't think the automatic would be different from the manual version in terms of the adaptive cruise control.
Generally no, but with manual the cruise control will be limited as it can only work within the range of the gear you're in - It wouldn't be able to e.g. go from 70mph to a stop without a lot of intervention from the driver. I never really got how dynamic cruise controls worked on manuals for that reason!
Not sure how it would work at low speed as they don't generally let you set them below 20mph, but that's about as fast as you'd want to go in 1st gear, so not sure how it'd cope!
I have the auto, and it doesn't go down to zero. Cuts out with a beep at roughly 15mph.
Ahh, good to know!
