RAV4 Sat Nav isuue
Brian Griffiths
I have a 2018 RAV4,Which has been in garage 5 times yes 5 times. The issue is the mileage clock on the satnav keeps changing to km
The garage initially suggested I should update the maps that hasn’t worked. If you switch the engine off then it returns to miles for a few days then changes to km again a few days later
i wondered if any one else have had a similar problem. I don’t know if the Toyota dealer doesn’t have the required skill to sort the issue out or if there is an inherent issue with the satnav that Toyota have not informed us about
Hi Brian, may be a software problem and require either an update or a reload.
Two questions for openers:
  1. Which multimedia system / satnav do you have in your car?
  2. What exactly do you mean by "the mileage clock on the satnav"?
I'm not aware of any issues in this space ...
On the satnav there is a speed limit which comes up so for example
instead of showing 30mph it’s 48
It’s been into the local Toyota dealer who has supposed to have spoken to Toyota they have changed the header unit updated the maps and system
when I pick it up they use language like hopefully it should be ok instead of we have found the issue and it’s now been fixes
Apologies for checking the blindingly obvious, but have you got the system setup correct?
Setup > General > Units of measurement = miles (MPG)
Which model, engine & which display is wrong the main navigation screen or the multifunction display by the speedo?
  • 10 months later...
How can I tell if2017 reg rav4 has sat an one Toyota garage says yes another says no when phoned .I thought it might need update but vaunt find out
