Rav4 2023 Terms of use and privacy notice window.
Hello everyone.
I have new Toyota rav 4. Every time I start the cat I get Terms of use and privacy notice window on screen. Even if I agree with terms, next time window appear again.
Is there any way to avoid this screen?
I believe that all you need to do is connect your car to your Toyota account - i.e. sign in to your Toyota account from the multimedia system.
Once you've done that, the system should remember that you've already agreed with the Ts&Cs; until you do that the car has no way of knowing that you are the same you ... 😉
Thank you for the hint. Problem solved!
Same question here. I don’t understand why Toyota don’t remember that you have provided your answer and so not ask the question again
  • 8 months later...
Hi tried the suggested fix, the QR code was not were I expected, so had a trip to the dealership. They eventually managed to link the account, all good now.
